Using Uno & Solo2 in same time
medamine60
Dear all,
I would like to use my Vu+ Uno and Solo2 in the same.
Uno is connected to 2 Tv's in two diferent rooms with HDMI spliter and Solo2 is conected to 1 Tv
Seens that they have the same RC, when I zap on Uno it's of corse zap also on Solo2
Any why to change the remote contole on one of them?
many thanks in advance
Dear all,
I think you can use different Mode
Search at the forum, how to change the mode for remote and image.
Do not forget to put back operation mode if you flash a new image.
Or you can use one remote with correct mode only for flash .
I have test on my Duo2 Mode 3 and working
Go to Green buton Plugins >>>RemoteControlCode
Change code in plugin and remote.
You have to make change on remote a quick (First, see where the Buttons)
If you have universal remote
You can change the system code of your Vu+ universal remote according to the Vu+ model that you want to control.
(By my test Mode 1 and 3 working on Duo2 and i think all other models standard is Mode2)
Mode1: Duo/Solo
Mode2: Uno/Duo2/Solo2
Mode3&4: For future usages
Press <<2+7>>, <Help>, <0001 or 0002 or 0003 or 0004>
1. Press 2 and 7 for three seconds until LED is on.
2. Press Help
3. Press 0001 for mode 1, 0002 for mode 2.
Hi,
Ohh Yes !! it's work perfectly now
thank you so much for your precious support
Wish you a very nice night
Amine
Both works well with the logitech Armony remote controle
Thanks a lot Matrix10
