How did you install it?Can not find Vali's EPG icon after installation!!!!!!
Please help
Tnx a911,2 ways...******* or normal..!
And it should be enabled from Menu >setup!
View attachment 5084 View attachment 5082
Then from channel button (^) U will see the above screen,,,,etc!
It works with Vu duo,,tested,,,!!
RgdZ
a911
Did you try with long press of epg botton?Can not find Vali's EPG icon after installation!!!!!!
Please help
Yes, you are right.Did you try with long press of epg botton?
I do not think epg long press will do the trick,,,an way I removed it already!
However,,,it will start from Menu>> setup,,from there U enable,,,then reboot STB!
Press the (^) of the channel @RC , Vail's EPG will show...it over lay the skin of the channel selection window!
RgdZ
a911
