vermin epg
Thanks Matrix for your answer.
My internet connection is OK and my HDD as well.
The URL defined in te system is http://www.vuplus-community.net/rytec/benl/epg.dat.gz that gives a 404 when copied into the browser ..... this is probably the issue ... any other idea on how to resolve ?
Thx,
GS
What kind of gz
You do not have the latest image with all updates.
CrossEPG and BH image as well as the OBH does not use gz files but xz files.
Black Hole image use CrossEPG and OBH image use EpgImport only xz files.
Sorry, I do not understand what you mean .... the http link I put in my message is not something I did myself, it was there when I go to EPG menu item from the main menu ....
I have BH 3.0.4.A, I believe this is the latest update, no ?
Well, exactly what I wrote
It tells me that you still have an old image where CrossEPG is old and not the last one with new links and xz files links but with old gz files and links.
And gz. does not work anymore
Install BH 3.0.4 and make all updates.
The latest update will be on today or the next days.
When I go to update BH image, the system comes back saying 0 packet to update .... I run 3.0.4.A .... what else can I do then ?
It is possible that the current update does not work properly.
We have some problems with the server.
Try it later.
I'll have to test this myself.
If update not working, then we will put an image on the forum.
And you have to install it manually.
OK many thanks for your time. In the meantime, I did a complete reflash of latest BH available version from the site, and did right after an image update via the addons.
It has installed 3.0.4 and updated 4 packets BUT the rytec epg config still show the URL I initially pasted into my message .... so indeed there must be something wrong somewhere.
Will try to update later on ....
I have re-installed BH 3.0.4 on Ultimo 4K
CrossEPG has been updated.
However, in info I can still see the old image version number BH 3.0.4.
I do not know if this is a complete update.
I informed the team about it.
It may be good (only the version number remains the same ??), and if not, we will put the image on the forum.
Just tried "(New) Rytec UK/Ireland Virgin XMLTV (xz version)" & it works a treat on a Solo2 running 3.0.4A...
Good evening guys
thank you for allowing me to join the forum. I am running the latest BH305 image on my Ultimo 4k and I have quite a lot of EPG missing on Vermin.
I am using CrossEPG and I have selected OpenTV provider for UK SAT, XMLTV for 1w and xmltv for UK/ireland (vermin is not in the list)
Any suggestions?
