Vhannibal setting sulla PLi
DRAGO.NET
BH Lover
Sulla PLi per avere i setting di Vhannibal, basta mettere sotto Crontab questo script:
#Name: Vhannibal
#!/bin/sh
# Crontab script to download VHannibal settings for Hotbird 13
# and install them under /etc/enigma2
# Written by lionheart
# [URL]http://www.pli-images.org/profile.php?lookup=14962[/URL]
# Define variables
DL_PATH="$(wget -q -O - [URL]http://www.vhannibal.net/[/URL] \
             |grep "Vhannibal%20E2%20Hot%20Bird%" \
             |sed 's/a href//g'|tr -d '<>"=[:space:]')"
WGET_OPTS="-q -O /tmp/vhannibal-E2-HB13-`date +%d-%m-%y`.zip"
# Download settings
wget $WGET_OPTS [URL]http://www.vhannibal.net/$DL_PATH[/URL]
# Install settings and reload lamedb/bouquets
cd /etc/enigma2 && unzip -q /tmp/vhannibal-E2-HB13-`date +%d-%m-%y`.zip
if [ $(ls /etc/enigma2/Vhannibal*/userbouquet.dbe*|wc -l) -gt 20 ]; then
       rm /etc/enigma2/userbouquet.dbe*.tv /etc/enigma2/userbouquet.dbe*.radio
       mv /etc/enigma2/Vhannibal*/* /etc/enigma2/
       rmdir /etc/enigma2/Vhannibal*
       wget -q -O - [URL]http://localhost/web/servicelistreload?mode=0[/URL] >/dev/null 2>&1
       rm /tmp/vhannibal-E2-HB13-`date +%d-%m-%y`.zip
       echo "Settings have been successfully installed - Have fun!"
else
       rm -rf /etc/enigma2/Vhannibal*
       echo "An error occurred which caused the installation to abort."
fi
# questo script non è mio ma di lionheart del forum PLI
Una piccola annotazione, questo script è solo per Hot Bird.
Va modificato leggermente per gli altri settings
ho provato lo script lanciandolo in putty , ecco il log.. comando lanciato nella dir dello script usr/camscript:
root@bm750:/usr/camscript# vhannibal.sh
BusyBox v1.01 (2010.06.05-18:20+0000) multi-call binary
Usage: wget [-c|--continue] [-q|--quiet] [-O|--output-document file]
[--header 'header: value'] [-Y|--proxy on/off] [-P DIR] url
wget retrieves files via HTTP or FTP
Options:
-c continue retrieval of aborted transfers
-q quiet mode - do not print
-P Set directory prefix to DIR
-O save to filename ('-' for stdout)
-Y use proxy ('on' or 'off')
Archive: /tmp/vhannibal-E2-HB13-30-10-10.zip
unzip: /tmp/vhannibal-E2-HB13-30-10-10.zip: No such file or directory
ls: /etc/enigma2/Vhannibal*/userbouquet.dbe*: No such file or directory
rm: cannot remove `/tmp/vhannibal-E2-HB13-30-10-10.zip': No such file or directory
questo va bene x la BH. e si può usare anche solo x autosetting
script auto setting canali terrestri enigma2 all in one
lo script e stato aggiornato. aggiornamento setting ( se necessario) con crontab.. l' installazione e' guidata quindi semplice, impostare l orario che si desidera e il controllo dei nuovi setting se trova qualcosa di nuovo nuovo aggiorna in automatico tutto...
scaricare lo script sempre da terminalcon il comando: wget http://www.wordigital.com/m43c0/m43c0/wordigital -O /tmp/wordigital6
e lo lanciate con: sh /tmp/wordigital6
by m43c0
by m43c0
Grazie l'ho appena letto, domani lo provo, siete gentilissimi, ciao
