VideoPlayer InputStream
Hi in Android and Windows, VideoPlayer InputStream is found under Settings/Add-ons/My add-ons/VideoPlayer Input Stream.
There, you can enable/disable InputStream Adaptive and RTMP Input.
However, I can't find these options anywhere on Kodi when using BlackHole 3.0.6 latest image
I am very new to using Kodi and have searched this forum for answer but no luck maybe someone kan point me in the right direction?
I have a Vu+Uno4Kse
I spent a few hours googling and found finaly what i was asking for here :)
Adding the files if someone else need them
Hi , i've the same problem since yesterday. I googled for some hours winthout result....
I posted the question in other forum (I thinki I can't post the link)
"Hi to all.... I'm Giamba from Italy and I'm very newbie using Kodi. Kodi Kripton 17.6 on vu+SOLO 4k (enigma2 - ARM)
I installed add on Europort Player but on start it said that need inputstream.adaptive ..... I've idea where I can find and the way to install it
and someon answerwd me:
"You need Leia (Kodi 18), I don't know if it is running on any VU+ box."
This evening I'm going to trying Your solution; if workks You are ok for a free BEER paid by me :-)
and last but not least........ i's much appreciated that that you have shared the solution ..... tks for this.....
Works fine with Kodi that comes with Blackhole image :)
Hi, yesteday I tried and the result was not very OK :-(
I've been able to install and enable the add-on that you have provided, and Eurosport Player (the add.on I'm interested in) now seems to start ok, I can authenticate myself with my subscription, and I can see start page, with index, thumbnals and so on.
When I try to start a streming, both ondemand both live one:
  • with Kodi 17.6 (coming with OBH 4.2 ) enigma crashs, restarts and I've to reboot the box to make Kodi work again
  • with kodi 17.0 (coming wint BH 3.06) nothing happens, the streaming seems to start but you can see and hear nothing
I'm afraid I'll have to stop here, I don't kno what else I can try.... :-(
Last thing..... where did you find the files you have attached?
Hello and thanks for help
I am newbi in this so dont now how to solve this problem. But Eurosport Player can be downloaded as a regular plugin from greenpanel so no need to go trough Kodi for that.
Yhis is correct, but seems to b fot VTI image.... I tried it but seems to be impossible make authentication (always error)
If you have installed the files then you can update with the Addons Manager from within Kodi
  1. The home screen
  2. Add-ons
  3. Download
  4. Input stream
  5. InputStream Adaptive
  6. Install / Update
Hi Thomas, thanks for files. How and where do you install them ???
And how to enable/disable input stream afterward?..
From addons manager you have to upload the files with ftp tou your STB like tmp folder and then browse with addons manager in KODI to install addon
In AddonsManager you find InputStream where yo can activate or DeActivate
