Videos resolution in Vu+ Duo2
medamine60
Hi all,
Some HD movies are playing in full screen and pictures seems stretched !
How to adjust resolution and autoresultion to make HD movie played with the black strip in top and bottom of the screen?
Many thanks in advance
Hi all,
If you are using Mediaplayer ( embedded on image ), doesn´t matter if you use Blackhole 2.1.7 or Open Blackhole 0.1 image, install MEDIAPLAYER2 with SUBSSUPORT.
Follow this guide on HOW TO DO IT --> http://www.vuplus-community.net/boa...diaplayer2-your-default-player-on-xbmc.23381/
There are links on the top of guide to the latest version, and in it there are some controls how to change the video size from 16:9 to 4:3 as too the policy ( pan&san, just scale, linear, letterbox ).
Hi nunigaia,
Where can i do this?
"and in it there are some controls how to change the video size"
Thanks
Hi nunigaia,
Thanks
What image are you using?
You must install this plugins, if not installed:
  1. Subssupport
  2. MediaPlayer2
After install, open Mediaplayer2, and when on playing a movie, press <5> button to change the size policy video settings.
Each time, you press <5>, you´ll see on the left top screen the "green" information of video.
Hi @nunigaia,
We can use this option (press 5) only with kodi?
I would like to have the same option for personnal video, dreamplex and IPTV? It's possible to config that?
Hi @nunigaia,
No. This an implementing for MediaPlayer2. So, if you use MediaPlayer2 as default plugin in KODI, the answer is YES.
If you use MediaPlayer2 to play your MEDIA VIDEO files ( personal video ), the answer is yes.
AFAIK, for dreamplex and IPTV, the answer is NO.
For MediaPlayer2 information you can look at:
https://code.google.com/archive/p/mediaplayer2-for-sh4/
