Hi, please introduce my configuration
Vu + Duo4kse 2 Sat 1 Dtt, with dual feed monoblock 13E-19.2E
I set the tuner "A" to DiSEqC A / B
And the tuner "I" Dtt
Everything works, I just have a problem with registering. I cannot record from two Mux at the same time. I think I need to set up the virtual tuners SatC D E F G H and Dtt J
How? Can you help me? Thank you
It may be better to eliminate this monoblock. Installs two Twin LNB's, the respective DiSEqC's (two with two ports) and you can still mix the signal with the terrestrial.
Then connect the two coaxial cables to the tuners, before "extracted" the terrestrial signal on the cable that transports it, then connecting to the terrestrial tuners.
Virtual tuners are completely useless with traditional LNBs (universal ones). You would really take advantage of FBC tuners only using Unicable/SCR/dCSS LNB.
Only, no dual feed is equipped by SCR LNBs: so, my advice is to get rid of this obsolete LNB and using one SCR for the satellite you prefer and where you want to have multiple recordings or PiP or streaming; the other sat can be received by a normal Universal LNB.
For instance: a SCR for 13E and a universal for 19,2.
Using a SCR, for instance a 16 user bands one, it's like having an LNB with 16 outputs, but using only on cable (that's why they are also named Unicable).
The tuner A is the physical tuner, while the other ones are virtual.
