Visible recording time longer than it really is.
tmykrk
Hi.
I have Vu + Duo2 with hdd. I have also enabled timeshift. The recording margins are 5 minutes. Some time ago I updated the packages and problems with recording from the satellite began.
The problem is that it does not record to the end.
Example. In EPG, I see that the broadcasting time is 45 minutes. I'm adding a timer. On the list of recordings I see that this recording has 75 minutes but when I play it ends after eg 40 minutes and suddenly the recording time is correct. The information disappears that it is 75 minutes long.
It does not matter which channel I record from.
Regards.
Tomasz
tmykrk
Hi.
My BH is 3.0.3 Q.
One more information. This is not always happening. It may be that I turn on 2-3 timers and badly recorded will be either 1 or 2 or all. It may also be that all will be good.
Regards.
T
