Volume Bar
Hi everyone,
may I install a different Volume Bar on my BH image?
Where is the file?
Thx.
Regards
The files you have to modify sholud be vol.png and volume.png in share/enigma2/skin_default for default skin.
My advice if to make a backup copy of the files you change, so if something goes wrong you can replace.
