VU+ + 600 Mbps Dual Band Wireless
Nowadays, is a nonsense to use a USB wifi adapter (that, incidentally, won't never be able to work at the nominal speed of 600Mbit/s, when the powerlines became so cheap and effective. And, above all, they need no driver.
Only precaution is not to plug them into a socket surge-protected.
The most comfortable ones are the ones equipped by a pass-by socket so that you can plug them at the wall socket and then, in case, use triple sockets or surge-protected devices attached to them.
