Vu+ Aggiornamento Drivers 11/11/2010
angelofsky1980
BlackHole Driver Specialist
VuPlus ha aggiornato i drivers per Vu+Solo e Vu+Duo!
Questi drivers sono installabili in immagini OE 1.6 compilate con GCC 4.1.1 o 4.4.3.
ChangeLog:
20101111
- Upgrade Linux DVB API driver to version 5(can be used with latest E2)
- Change dvb-core to use v4l-dvb(with additional patch)
- Change LED Color at standby(solo)
- Support vtuner at solo
- Fix vtuner audio/video sync problem.
- Clean up and fix misc. bugs at vtuner driver.
- Fix USB transfer problem when both front and rear ports are in use
simultaneously (solo)
- Disable HDMI hotplug at standby mode
Vu+Duo:
gcc-4.1.1
gcc-4.4.3
Vu+Solo:
gcc-4.1.1
gcc-4.4.3
