Vu+ Aggiornamento drivers per Duo/Solo/Uno del 06-10-2011
angelofsky1980
BlackHole Driver Specialist
Vu+ ha rilasciato un aggiornamento dei drivers per Duo, Solo e Uno!
- improve DVB-C/T tuning(uno)
- Fix incorrect display of DVB-C/T SNR/AGC(uno)
- Fix high-bitrate problem in CI(uno, needs a FPGA update, New Rev 4.2 FPGA image is at http://archive.vuplus.com/download/fpga/vuuno/4.2/)
- Support 3D framebuffer
- Add interface for UI position setup
- Add redundant fpga device at /dev (uno)
- Add ioctl for hdmi_cec(get physical/logical addr.)
- Fix audo mute in pass-through(uno)
- Add interface to set the system code of the remote control(uno)
- Add interface to disable REC VFD icon(uno,duo)
- Add interface to control global alpha
Duo
Solo
Uno
