VU+ and Harmony hub settings
Blusat
Hello,
has anyone of you an harmony hub (by Logitec) to control your VU+ and home cinema.
VU+ is defined in the harmony system but I am struggling if i need to write a script with the tv channels (like for instance, switch ON the tv / ampli / sat receiver and select channel 4).
the system mixes the channel number I use in my favorites and the channel numbers in the "all channel" view.
I could use the "all channel" number except it keep changing if I re-scan the satellites.
thanks in advance.
