Hi,
After I install an IPTV autoscript, my VU box crashes.
I have attached the following error log:
config.EMC.movie_picons_path=/media/hdd/movie
config.EMC.movie_save_lastplayed=true
config.EMC.movie_trashcan_enable=false
config.EMC.movie_picons=true
config.EMC.movie_cover=true
config.EMC.movie_exit=true
config.EMC.movie_preview=true
config.EMC.latest_recordings=false
config.EMC.movie_show_format=true
config.EMC.movie_picons_path_own=true
config.EMC.skin_able=true
config.EMC.symlinks_show=false
config.EMC.directories_show=false
config.av.avl=hdmi
config.av.videorate.1080p=60Hz
config.av.videorate.1080i=60Hz
config.av.surround_3d=hdmi
config.av.videomode.DVI=1080p
config.av.autoframerate_mode=auto
config.misc.rcused=0
config.misc.firstrun=false
config.misc.initialchannelselection=false
config.misc.epg_data_timer=30
config.misc.startCounter=78
config.misc.languageselected=false
config.misc.defaultchosen=false
config.misc.epgcache_filename=/media/usb/epg.dat
config.misc.allow_service_delete=true
config.misc.videowizardenabled=false
config.Nims.1.configMode=advanced
config.Nims.1.advanced.unicableconnectedTo=0
config.Nims.1.advanced.unicableconnected=true
config.Nims.1.advanced.sat.192.lnb=1
config.Nims.1.advanced.lnb.1.lof=unicable
config.Nims.1.advanced.lnb.1.unicableLnbManufacturer=Inverto
config.Nims.1.advanced.lnb.1.unicableLnb.Inverto.product=IDLB-QUDL-UNI2L-OPP
config.Nims.1.advanced.lnb.1.unicableLnb.Inverto.vco.IDLB-QUDL-UNI2L-OPP.1=1420
config.Nims.1.advanced.lnb.1.unicableLnb.Inverto.vco.IDLB-QUDL-UNI2L-OPP.0=1210
config.Nims.1.advanced.lnb.1.unicableLnb.Inverto.scr.IDLB-QUDL-UNI2L-OPP=2
config.Nims.0.configMode=advanced
config.Nims.0.advanced.sat.192.lnb=1
config.Nims.0.advanced.lnb.1.lof=unicable
config.Nims.0.advanced.lnb.1.unicableLnbManufacturer=Inverto
config.Nims.0.advanced.lnb.1.unicableLnb.Inverto.product=IDLB-QUDL-UNI2L-OPP
config.Nims.0.advanced.lnb.1.unicableLnb.Inverto.vco.IDLB-QUDL-UNI2L-OPP.1=1420
config.Nims.0.advanced.lnb.1.unicableLnb.Inverto.vco.IDLB-QUDL-UNI2L-OPP.0=1210
config.Nims.3.configMode=advanced
config.Nims.3.advanced.unicableconnectedTo=2
config.Nims.3.advanced.unicableconnected=true
config.Nims.3.advanced.sat.192.lnb=1
config.Nims.3.advanced.lnb.1.lof=unicable
config.Nims.3.advanced.lnb.1.unicableLnbManufacturer=Inverto
config.Nims.3.advanced.lnb.1.unicableLnb.Inverto.product=IDLB-QUDL-UNI2L-OPP
config.Nims.3.advanced.lnb.1.unicableLnb.Inverto.vco.IDLB-QUDL-UNI2L-OPP.3=2040
config.Nims.3.advanced.lnb.1.unicableLnb.Inverto.scr.IDLB-QUDL-UNI2L-OPP=4
config.Nims.2.configMode=advanced
config.Nims.2.advanced.unicableconnectedTo=1
config.Nims.2.advanced.unicableconnected=true
config.Nims.2.advanced.sat.192.lnb=1
config.Nims.2.advanced.lnb.1.lof=unicable
config.Nims.2.advanced.lnb.1.unicableLnbManufacturer=Inverto
config.Nims.2.advanced.lnb.1.unicableLnb.Inverto.product=IDLB-QUDL-UNI2L-OPP
config.Nims.2.advanced.lnb.1.unicableLnb.Inverto.vco.IDLB-QUDL-UNI2L-OPP.2=1680
config.Nims.2.advanced.lnb.1.unicableLnb.Inverto.scr.IDLB-QUDL-UNI2L-OPP=3
config.seek.selfdefined_46=60
config.seek.selfdefined_13=15
config.seek.smartseek_marker=true
config.seek.selfdefined_79=300
config.osd.language=de_DE
config.tv.lastroot=1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "bouquets.tv" ORDER BY bouquet;1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet;
config.tv.lastservice=1:0:19:83:6:85:C00000:0:0:0:
config.usage.on_movie_stop=movielist
config.usage.servicelist_picon_dir=/media/usb/picon
config.usage.movielist_show_picon=true
config.usage.plugin_sort_weight={'chromiumos': {'sort': 30}, 'bildbetrachter': {'sort': 10}, 'vti hdmi-cec': {'sort': 170}, 'code der fernbedienung': {'sort': 40}, 'youtubetv settings': {'sort': 190}, 'piconmanager (mod)': {'sort': 120}, 'mediaplayer': {'sort': 70}, 'schneller IPTV Free Test kanalwechsel (fcc)': {'sort': 130}, 'openwebif': {'sort': 110}, 'blindscan': {'sort': 20}, 'zapping-modus': {'sort': 200}, 'transkodierung konfigurieren': {'sort': 160}, 'men\xc3\xbc positionieren': {'sort': 90}, IPTV 'mediascanner': {'sort': 80}, 'epgsearch': {'sort': 60}, 'dvdplayer': {'sort': 50}, 'streamtvplayer': {'sort': 150}, 'vti panel': {'sort': 180}, 'men\xc3\xbc-3d-einstellungen': {'sort': 100}, 'solo4k misc. control': {'sort': 140}}
config.usage.use_pig=true
config.usage.movielist_show_folder_info=false
config.usage.show_epg_progress_percent=true
config.usage.days_mark_as_new=0
config.usage.quickzap_bouquet_change=false
config.usage.movielist_show_last_stop_time=true
config.usage.timeshift_path=/media/usb2/
config.usage.picon_dir=/media/usb/picon
config.usage.channelzap_w_bouquet=true
config.usage.movielist_show_dir=false
config.usage.servicelist_show_picon=50
config.usage.movielist_show_file_size=false
config.usage.use_extended_pig_channelselection=true
config.usage.movielist_show_recording_date=false
config.usage.epg_default_view=singleepg
config.usage.movielist_last_played_movie=1:0:0:0:0:0:0:0:0:0:/media/hdd/movie/20161101 2327 - ZDF HD - Markus Lanz.ts
config.usage.movielist_show_duration=false
config.usage.allowed_timeshift_paths=['/media/usb2/']
config.usage.only_unseen_mark_as_new=true
config.usage.movielist_show_folder_info_new=false
config.usage.movielist_show_folder_info_sort_by_new=false
config.usage.show_infobar_on_event_change=false
config.usage.epg_buffer=20
config.usage.movielist_duration_in_min=false
config.usage.debug_config=off
config.usage.show_old_epg=0
config.usage.movielist_only_day=false
config.usage.on_movie_eof=quit
config.usage.movielist_show_folder_info_only_new=false
config.usage.hdd_standby=60
config.usage.use_rm_force_depends=true
config.plugins.devicemanager.enable_hotplug=true
