Vu+ channels over DLNA
dreamingb
Hi Devlopers
First of all thanks for your great efforts to create vu+ a Rock solid sattelite tuner. You guys has done a great job and very impressive results when it comes to images.
Recentlly i came across an application called dvblogic. Then i thought why don't we can include a feature like this in a vu+ ultimo/duo. Provide the channels over DLNA. As i know BH images has inbuilt DLNA server but is it possible to use that server to give channel access as well?
This could be a great feature for ultimo with 3 tunner option so TV's having inbuilt wireless and DLNA can play channels from Vu+ over wireless. I have tested with dvblogic and its working great. The only thing is that i need to have pc beside the vu+ which can get stream from vu+ and convert it to dlna. Sometime Windows crashed as you know and then you need to restart and then so on. But dvblogic cannot handle multi channels from same transponder to different client which is being handled by vu+ nicley.
So please guys take a look on that feature that could be very nice for upcoming future.
I agre it will be great to have that in BH.
This feature already exist in Rudream image, I use streaming over DLNA with my phone android (app: UpnPlay) and it work great.
You already have this in BH.
I will post a tutorial soon.
Hi Shiro,
you said that " you aalready have this feature in your Ultimo".
can you explain how do you get tv channel from vu+ultimo through dlna.
Because i succeeded with a solo2 and duo2 , but never could make it work
with a regular Vu+ like duo or ultimo.
Assuming that all vu+ were all with latest firmwxare 2.0.7
I used exactly the same setting on all these receiver, only solo2 and duo2 worked,
with regular receiver , ok you can see playlist on television but when you select a
channel tv set says after a while , "impossible to play or unreadable file" on that same tv
with duo2 it's ok.
Does that mean that Dlna will only work with latest recevier from Vu+ ?
thank you
