Vu + clones !!
bojja
Yesterday i heard that there are the vu+ clone ones on the market!!.Now when i go to buy another vu+ receiver how will i know if is original or clone.Is there any plugin for Genuine VU or something else?Thanks.
NO Vu+ Clone!
And always buy from Vuplus certified dealers,,,,!
RgdZ
a911
No, at the moment, there isn't any plugin to do it.
To be sure of your next purchase, you have just to choose a reliable seller.
who found web to identify it?
A voice without real confirmation or real clone on hands ... it's only a voice.
Buy from certified Vu+ reseller/distributor.
If you have bought a suspect clone, post hi-res photos and report in what shop you have make buy.
a friend on web got 1 vu+duo for 175euro from **********, he tell me that the duo clones work perfect with all images and there is no need patched image for it
photos are too on *******
the chinese says vu+ultimo should be available from march 2012
a friend on web got 1 vu+duo for 175euro from *******.com, he tell me that the duo clones work perfect with all images and there is no need patched image for it
We need some infos about vendor on *******.com .
lets Keep our forum clean,,,,enough talk about colon,,,,its illegal!
I would recommend closing of this topic,,(thread),,,and delete all codes,,,etc!!
You are right but this thread can be useful at the end to catch infos to be turned to Vu+ to fight against clones.
@a911: ok.
This thread will be closed and talk about clones (true o false) are forbidden in this Board.
In the next hours the Board rules will be updated with this new rule.
Thread closed.
