T tsouli Vu+ User Mar 2, 2013 #1 hi, i want to know how to add a dns server to my vu+,? it's possible?
Mito Administrator Mar 2, 2013 #2 Yes you can. Menu > Setup > System > Network > Nameserver settings...
T tsouli Vu+ User Mar 2, 2013 #3 Mito said: Yes you can. Menu > Setup > System > Network > Nameserver settings... Click to expand... thaanks,that improve the performance of connection in my box ???
D darian23 Vip Mar 2, 2013 #4 It could, it depends what you use at the moment: dhcp or static address?
T tsouli Vu+ User Mar 3, 2013 #5 darian23 said: It could, it depends what you use at the moment: dhcp or static address? Click to expand... dhcp
D darian23 Vip Mar 4, 2013 #6 then your dns is automatically read from your dhcp server. You do not need to enter it manually
