vu duo 2 --- > dvb-t t2 tuner
difficult_guy
Hi guys
if I buy vu+ duo 2 original
can I tune virgin/cable channels in uk? does it have dvb-t t2 tuner built in
as far as I know, it has got deb-s2 but I am not sure about dvb-t t2 tuner is any different or if I need any software update to do the magic?
Hi guys
You need a DVB-T2 tuner installed on your Duo2 box.
The VU+ Duo 2 has two separate, internal, tuner slots, that are simple, plug & play, slots, similar to fitting a graphics card, on a PC.
You can mix, satellite, and cable/terrestrial tuners, or have both fitted with satellite tuners, giving you 4 satellite tuners.
You want a Vu+ Hybrid DVB-C/T/T2 Tuner for Uno / Ultimo / Duo2 Plug and Play, which you can get from Lee, at Goldwafers, where I bought my VU+ Duo 2, or from other suppliers.
http://www.goldwafers.com/cart/Vu-Hybrid-DVB-C-T-T2-Tuner-for-Uno-Ultimo-Duo2-Plug-and-Play.html
Can you direct to right place where I can buy and set up this tuner please... I am new user of VU+ duo2 box
HM-Sat-Shop
https://www.hm-sat-shop.de/en/hdtv-receiver-sat/vu-/513/vu-duo-2x-dvb-s2-tuner-pvr-ready-twin-linux-receiver-full-hd-1080p
Here you can choose all combinations of tuners, before buying your Duo2.
Make sure to choose "Dual" tuners. The tuners where the word "dual" is not mentioned, is all single tuners.
Best regards
