Help...
In records folder i see only files and not the directories.
Thanks
Help...
Thanks
Recorded materials is in folder movie on Hdd.
I have sub folders inside movie folder and I cant see those sub folders.
Thanks.
Special button on remote shows movie folder.
You can select from a list to play them but you can't see the sub folders.
If you click 2 times the records button you must see all folders and you can bookmark the folder what you want.Help...
Thanks
