Vu+ duo 2 tuner problems
vivalabam88
Hello everybody,
I have a problem with a second hand duo 2.
Most channels on 23,5 have pixalation. Sound quality isn't very good too. Have to set it on left or right then it sounds a lot better.
I also have a solo 2 and this has no issues so that means, I think my cables and dish and lnb are alright.
As the box gets warmer some channels look like they are getting better. I also have 2 tuners installed switched them in the box itself. No effect both tuners have the same problems.
Does anybody know what is causing this problem? Bad caps?
Thank you
Who can know what this box will have, having the years you have, acquired in second hand!
If after heating gets better, wear it on top of an electric stove!:lol:
