Vu Duo 2 with Black Hole Image - Help pls
poacher1
I am trying to find a way to look at the 7 day planner to record programmes as in the same way my sky box does.
When I go into the EPG it only gives limited information.
Can anyone help me please.
Download plugin called coolmantvguide off BH server. Green button>yellow button>download manager and addons its in there bud.
nope - its still not happening for me
If you've downloaded it ... Long press blue button and select cooltvguide... Use the yellow button to change the view type once in it. And use green to add timer or long press green if you use autotimer
