VU+ DUO 4K SE Channel touch buttons not working
Hello ,
Using Vu duo 4k se device, having problem with the touch buttons on the device.
While I am touching the "Channel +" or "Channel -" button the EPG windows appears.....
I would like to use this button for the purpose of channel change...
Probably some change needs to be done in keymap.xml , unforutnattely I am a newbie and I don't know how to do it on this device
Thanks for support
Using open atv 6.4 version
This forum is for BH or OBH. For OAtv you need to ask their forum (good luck if you don't speak German :D 'cause they seem not to know there isn't only German in the world).
