Vu Duo 4k sound echo/vibrating.
scorpion007
Hello, I have noticed after watching some channels the sound goes funny kind of echo/vibration noise, I have to switch the channel then go back and it goes back to normal. I have seen sound fixes on the image updates but the problem remains. Is this another VU fix we have to wait for?.
I did not notice it on my box and Samsung UHD TV.
First of all try another hdmi kabal if you have not already.
Try another input for HDMI on your TV.
Known issue. Sound starts stuttering, video is ok. Zapping solves the issue. It happens randomly, no pattern.
Driver problem...
Sent from my HTC U11 using Tapatalk
Hola, yo también tengo el mismo problema de sonido, con Vu+ Duo 4K que Scorpion007, el sonido a veces empieza a tartamudear, y con retraso de 8 segundos y tengo que cambiar de canal y volver a mismo canal para que se solucione, con Black hola el problema se presenta muy pronto, con VTI tarda mas tiempo en aparecer el problema. Hay alguna solución ?
No solution, as above it's a driver issue.
A esperar si alguna actualización corrige ese problema. espero y deseo que sea rápido. muchas gracias por la respuesta Ev0
New drivers have been released that should fix this issue now.
So online update BH 3.0.9.F (or OBH 4.3.006) to get the latest drivers.
