Vu+ DUO blackhole problems
bartalisattila
Hy
I have a Vu + duo with Vuplus experimetnal 2016-12-14 . I have 2 problems .. PLease tell me why is freezing Youtube TV at the start( just red image ) and how can i delete channels? I tried with menu button but i dont have delete options.
Thank you
Best regards
Attila
Hy
Thank you
Best regards
Attila
Is it original image not blackhole?
You can only delete channels in your bouquets (Favourites), using the menu options, at least in Blackhole.
To delete a channel, from the main list, you need to use dreamboxedit, then download your channel list, from your receiver, edit it, then FTP the newly edited list back to your receiver.
