Geronimoxx
VU+ Duo with pli image, Triax 78cm, 13-19.2-23.5-28.2.
When i connect cable from box direct to cable from lnb everything is fine. With a diseqc (venton) and a restart it defaults to Sky Sport HD2 (19.2 sky germany). And i can switch to 28.2 channels also 23.5. But after a while i cannot change channels(other sats) anymore. It gives 0 Db on the channels. It looks like it doesn't switch the diseqc. The A in the bottom of the screen(tuner A stays yellow). I only use one tuner.
Problem started a few weeks ago. The sat arm was bent and i replaced it, did use the old dish. Replaced cables to lnb and used 2 diseqcs all same problem. Also updated the image.
With diseqc all sats are fine with, it does want to switch all the time. Read some stories about condensator, but the box is alittle over a year old. HDD built in, not standing in cabinet.
Thx
Thx
. This is BH support forum, not PLi
. Sorry, flash BH 2.0.3, afterthen we can help.
