Vu+Duo doesn't list USB DVB tuner, Terratec Cinergy DT XS Diversity
blueye
Hi, I plugged in a Terratec Cinergy DT XS Diversity USB but I can't see it in my tuner list (I see only the two sat internal tuner).
root@bm750:/proc/bus# cat nim*
NIM Socket 0:
        Type: DVB-S2
        Name: BCM7335 DVB-S2 NIM (internal)
        Frontend_Device: 0
NIM Socket 1:
        Type: DVB-S2
        Frontend_Device: 1
I use the latest release of BH: 2.1.7
Attached you can find the debug file, hope it can help.
NIM Socket 0:
        Type: DVB-S2
        Frontend_Device: 0
NIM Socket 1:
        Type: DVB-S2
        Frontend_Device: 1
The error is
CPU 0 Unable to handle kernel paging request at virtual address 00000040, epc == e1253034, ra == e10f4808
Oops[#1]:
Cpu 0
$ 0   : 00000000 00000000 00000008 e12555f4
$ 4   : 00000008 e1259114 00000000 00000008
$ 8   : 00000000 00000000 e125911c 000562eb
$12   : a2c4d11a df553007 78347991 91d922c6
$16   : 86b2894c e10f0000 00000000 00000008
$20   : e1040000 e108f7ec e108f86c 00000000
$24   : 4f81cef4 8005ab5c
$28   : 86656000 86657b78 e10f977c e10f4808
Hi    : 00000000
Lo    : 00000000
epc   : e1253034 dib7000p_attach+0x10/0xd0 [dib7000p]
    Tainted: P           O
ra    : e10f4808 stk7700d_frontend_attach+0x4c/0x22c [dvb_usb_dib0700]
Status: 10008703    KERNEL EXL IE
Cause : 0080000c
BadVA : 00000040
PrId  : 0002a044 (Brcm4380)
Modules linked in: dib7000p(O) dvb_usb_dib0700(O+) dib0090(O) dib7000m(O) dib0070(O) dvb_usb(O) bh_rc_core(O) dib9000(O) bh_dvb_core(O) dib3000mc(O) dibx000_common(O) brcmfb(O) dvb_bcm7335(PO) procmk(O)
Process modprobe (pid: 264, threadinfo=86656000, task=865cf730, tls=77d39490)
Stack : 00000005 e1039ce4 00000000 00000008 00000000 86b2894c 86b2894c 86b2894c
      e1040000 e1090198 e10f977c 80537b7c 00000000 86b2894c 86b2894c 800c0000
      e10f8510 e10923dc e1090000 e1092428 86b28000 e108ed18 8669d380 86b280d0
      00000000 86b28954 e10f977c 00000001 80537b44 00000000 00000000 86651208
      00000000 80133000 86b28954 86b2895c 86b2894c 885e5c08 00000003 e1100000
Call Trace:
[<e1253034>] dib7000p_attach+0x10/0xd0 [dib7000p]
[<e10f4808>] stk7700d_frontend_attach+0x4c/0x22c [dvb_usb_dib0700]
[<e1090198>] dvb_usb_adapter_frontend_init+0xe0/0x1cc [dvb_usb]
[<e108ed18>] dvb_usb_device_init+0x594/0x87c [dvb_usb]
[<e10f00d4>] dib0700_probe+0x98/0x1b4 [dvb_usb_dib0700]
[<803b8848>] usb_probe_interface+0xf8/0x234
[<802fc220>] driver_probe_device+0xa0/0x2bc
[<802fc4f8>] __driver_attach+0xbc/0xc4
[<802fa590>] bus_for_each_dev+0x5c/0xa8
[<802fb7f8>] bus_add_driver+0x110/0x278
[<802fc894>] driver_register+0x90/0x1a0
[<803b7cec>] usb_register_driver+0x90/0x17c
[<80001588>] do_one_initcall+0x160/0x1e8
[<80073790>] load_module+0x192c/0x2120
[<80074038>] sys_init_module+0xb4/0xec
[<8000e19c>] stack_done+0x20/0x40
Code: 00801021  3c03e125  246355f4 <ac830038> 3c03e125  24633984  ac830034  3c03e125  24633108
---[ end trace 4d26e27240c5a514 ]---
I'll investigate.
il mio terratec cinergy micro usb, come 3° tuner lavora alla grande e senza alcun problema.. con L'em28xx .. è bastato installare il driver e resettare!
ok.. but for me ther is:
xxw.facebook.com/372055172991280/photos/a.417523448444452.1073741829.372055172991280/417523565111107/?type=3&theater
ps : sulla versione BH by robijay non lavora, attention,
version BH by robijay not working.
????????? BH by robjay chi è scusa?
Questo robjay!
- url removed - next time you will be banned -
OK Sorry ..bat you asked and I said.
I've asked, you have sad BUT our Board rules that you have accepted during registration are clear. No illegal materials allowed here and no backup images.
Pur here the link (I've removed it) mean publicize that backup image. I can suppose you are using that ... I'm right?
Si ho capito e per questo ho chiesto scusa .. se potessi togliere il riferimento a "R.." nei miei post te ne sarei grato io non posso farlo
Fianlly I bought an usb tuner from Amazon, its name is
August DVB-T 202
BlackHole recognized it and it works well... obviously, to make it works, I had to use a powered usb hub too.
------------------------------------ Italian ----------------------------------------
Alla fine ho comprato un tuner usb su amazon, si chiama
August DVB-T 202
ed è stato riconosciuto subito da BlackHole, funziona bene... ovviamente per farlo funzionare bene ho dovuto abbinare un hub usb alimentato.
