Vu+Duo freeze
glog
Need help. My duo freeze somtimes after minute, somtimes after day of work. Remote stops responding, i can not change the channels or do anything with remote. Box keeps playing current channel, display freeze, but i can watch the current channel without the problem. So im stuck with current channel.
In this freeze mode ftp and openwebif works fine. If i restart box via openwebif it just stays in freeze mode, i cannot use remote or manual commands on the box.
Im currently running BH 2.0.8.1. but i also try many images the result is the same. Older BH images have the same problems. Box is 1,5 years old.
Im not using hdd, just usb, i did try without usb, same thing. I did test box to work without the cover to exclude overheating, did not help. Fan is also working fine.
What to do? Please help.
Any suggestion? Is it PSU? Box sometimes goes to completely in off state by it self. Even the red light is off. Only power switch can bring duo alive after.
Please help.
