I have Vu+ Duo with original image (Black Hole Enigma 2010-12-21)
I installed a used windows 250 Gb Hard disk.
First I could not get it to initialize but then managed to format it with computer for Linux.
Then Vu+ Duo found disk and I could initializing and check file system.
When I go to Hard Disk, I see Detected HDD: ATA(ST3250820AS).
I'm able to record, so all seems okay.
If I however switch Vu+ Duo completely off (remove plug from socket) and then switch back on later, it seems that Hard Disk has lost initialization because when I press record, I get error message that HDD is not initialized. I still find Hard Disk in menu and can re-initialize it. Then it works again.
So basically every time I switch on I need to initialize Hard Disk again.
Does anyone has same problem or solution ???
