VU Duo Help Needed
bobthebob
HI
I am trying to flash my Duo using BH 2.0.8 on USB dongle
I have OpenPLI in and it frozen
so I through i could reflash it using BH
When I plug in dongle I get a massage saying reading USB then i gwt a massage saying Starting and that is all i get
I have tried to reflash it using others but i just get the same massage
Please is their a way out of this
Or should I just put it in the BIN and just forget about it
It is just over 1 year old
Regards
Bobthebob
HI
Regards
Bobthebob
Are you sure you have unzipped file before install to usb stick
thanks for your reply
Yes I use WinRar to unzip my files
Just to let you know how i unzip and what files i use
I make a file call it VUPlus
then a nother file called duo this file goes in side the VUPlus file
I then open tje zip file and ectract it into the VUPlus
am i right so far ???
or have i gone wrong ???
hi bobthebob, just wondering if you managed to get your duo working ? i have the same problem, my duo will not flash either no matter what version of bh i try. i have even had the capacitor and a new regulator fitted as suggested in previous threads but my box will still not flash. if anyone elase can shed some light on this, it would be much apreciated
