VU+ duo image advise
hs5424
Hi All.
I need to set up a VU+ duo for a friend. However as I currently own one for the past 18 months I do have intermittent problems with epg download having to reboot the box and then force a download for epg's to return. Occasionally it will only display two or three recordings on the hd even though a lot more exist. Rebooting also resolves this problem. As my friend is a non technical guy I know that the problems mentioned will cause him to 'crack up'. Can anyone suggest an image that is hassle free. I have tried two BH images, the current one being 1.7.2.
Thanks in advance.
hs5424
