Vu+ Duo keeps rebooting after installing an addon
Laffe
I installed the addon for airplay, and now my box will not restart. It keeps comming with an error saying software error, and reboots.
There is an error log that I can share if you can tell me how to access it.
I am a total noob to this (mostly) and I am not sure how to access the log.
Can anyone help me?
I had someone set it up for me. I can give the box back to him, but I would rather not.
It takes a while to get it back.
Any help is deeply apriciated.
Laffe
Thanks mate.
I found a few, so I zipped them all up into one.
I also took a picture of my tv screen and added that to the file.
Hope someone can figure this out
Mine did the very same thing. I solved it by reinstalling the firmware once Again. That was the fastest solution for me. Hope it gets fixe because it's a wonderful feature - so thank you very much to those who made this possible.
Thanks mate.
Can you test with 2.1.2 and make this the first plugin you try before you make any other changes ?
Im afraid I have no idea how to do that. As i mentioned, I havent set the box up myself. And will i loose files if I do that? If you know what I mean ;)
