VU+ Duo Kodi Direct
ashleyde
Hello VU-PLUS Community
Im having issues with the Kodi direct plug-in - None of the add-ons run ? I have uninstalled and re-installed the Kodi direct then added back in the add ons , None of the run / open ?
Any ideas would be greatly appreciated
Cheers
Ash
Cheers
Ash
Wich image are you using on your Vuplus Duo STB?
I didn't know Kodi could run, on the older VU+ Duo receiver.
@Mick12334 my answer has almost one year dated. Kodi Direct was working on 1st generation Vuplus STB´s, although the author ( pcd ) has stopped its development.
So, there´s no more a workable kodi direct version, because is no more supported.
