VU+ Duo Loops GSD on startup
RedJag
Hi All,
First post so please bear with if I ask something that is easy to fix...Returned home from work to find that the STB is constantly going into a loop resulting with GSD. Last line I can see on the crash report before it-boots again is:
twisted.internet.error.CannotListenError: Couldn't listen on 0.0.0.0:80: [Errno 125] Address already in use.
Not sure what has caused this or how to interrupt the Loop. It happens if the re-boot the machine from switching off and complete power down/power up.
Thanks
Hi All,
Thanks
Seems a problem related to something you have installed like old WebIf and new OpenWebif.
Thank You angelofsky1980.
As far as Im aware nothing has been installed but the STB has been freezing regularly over last few days.
However in order to investigate, my challenge is how to break the looping so I can at least try and work on the STB.
Any ideas gratefully received
