VU+DUO No Hdmi
bahram fazeli
Good day to you,
I have had a VU+ DUO running OpenVix. I recently lost the signal through HDMI however the Scart socket works fine. Is this a hardware problem or something to do with the setting.
Kind regards
First of all, this forum is not for OpenVix but for BlackHole and OpenBlackHole.
By the way, if you are sure you did not change by mistake any AV setting, it seems a HW problem. But to be sure you could try to reflash your box and go through the initial wizard for setup.
It'd be also a good motive to try BH or OBH ;)
Thank you Alex, I will do that.
Where do I find BH image for VU+DUO ?
Cheers
