VU DUO PROBLEM
MiroHD
Hey , Please whenever i am connecting my USB TO MY VU DUO And Recording and connecting the usb to the pc the usb doesnot appear on my Windows 8 PC How to fix that i want to watch things on pc as well ! Please Help AND THANKS !
Have you formatted/partitioned the USB stick with your box?
If YES it's formatted with Linux filesystem and you find a software for Windows who can read Ext(2,3,4) filesystems
For a USB stick that is used only for recording is not necessary to format the stick in VU + box in to Ext(2,3,4) filesystems but only mount.
In this case format USB stick on PC format FAT32.
Mount USB stick in BH Device Manager (and NOT FORMAT with USB Format Wizard)
Note recording HD programs on a standard USB stick
does not make sense because the speed is to low.
Where SHould i Mount The Points To ? Media/USB or Media/HDD ?
