Vu Duo R1 which image is suitable?
mase2hot
Hi All
I have the 1st version of the Vu Duo, which Image should I be using. I'm currently have Blackhole 3.0.2.H and not sure what image my hardware will support up to?
Also not sure best way to update channels currently I use cateyes or vhannibal but both dont get my ss news which seems to have gone.
If someone could point me in right direction that would get great.
Thanks!
To vu duo bix is still developed image BH last is 3.0.3.
Try setup on your usb swap around 128mb and use multiboot to have image on usb this give you more space and more posibility in image.
Try image OBh 1.0 too; this image is light and alot people used he on first generation box.
If im good undrestebd thsi 2 setting no have chanell " ss news ".
Maybe devlopers thsi setting add he in other name or update in future.
But if you have other setting wuth thsi chanell try send he to box by Dremboxedit from your computer
I have checked frequency on lyngsat and mine is correct but still not working even though I have 86% snr. Any ideas?
Try a manual scan for the frequency you need or a complete scan of that satellite. Why everyone wants everything fast and ready by external settings packages? Decoders are able to perform a scan by their own. Yes: this needs incredibly 5-10 minutes of our life, but ensures the best results.
Haste makes waste.
OK, because you wrote you "checked frequency", not performed a scan.
What satellites broadcast this ss news? I can't find in KingOfSat.
I did but didnt mention as I said sorry. Just been told ss news and some sports channels are not available at present so thats probably why.
Actually, I can't find any channel named SS NEWS neither on 28,2 nor anywhere else. Did you write it right? What's its frequency?
