My Vu+ Duo is probably almost 4 years old, and I've recently reflashed with the latest BlackHole (2.1.1).
It locks up regularly, sometimes a few times an hour, and during each lock up audio and video will freeze for 2-30 seconds. I'm trying to figure out what's causing it; is it config or failing hardware?
There is a 256MB swap file configured on the same 4GB USB stick that is used for EPG.
This is typical free report.
root@bm750:~# free
total used free shared buffers cached
Mem: 138464 134256 4208 0 436 18204
-/+ buffers/cache: 115616 22848
Swap: 262140 25500 236640
Typical System Info report; RAM 97%, Swap 9%, Total Mem close to 0, HDD Temp 33, Flash 80%, HDD space 60%, USB 15%, CF close to zero, Total space 60%.
My suspects (1) connection to friend (2) EPG setup (3) hardware?
(1) I have a connection to a friends system that I won't get into a lot of detail about, but sometimes the hangs seem to happen around the same times that I get long pings to that system (from normal pings of 45ms up to 100ms plus). But not always, sometimes the pings are fine and it still hangs. (I keep a ping -t going while investigating)
Is this the most likely reason, and other than change ISP [planned], what could I do?
(2) I'm not fully sure that I have EPG setup the right way, because EPG data is only populated for some channels. I think I might have 2 EPGs setup, CrossEPG and the native one. I've read that having 2 EPGs can cause problems, so I'm trying to read more to understand how to set it up right.
(3) Hardware. Is it anyway likely that the hardware could be failing? Any tests I could run?
root@bm750:~# free
