I have had My Vu+ Duo for a couple of years and suddenly my remote has started behaving in a peculiar manner. The FF and FR don't work properly. If I press the FF button it does 2x but no more. I found if I pressed the right arrow key it did 4x then FF key 8x etc. Also when I navigate menus the highlight gets stuck and only moves if I press a right/left arrow or up/down. When stuck the exit button doesn't work. I did find a thread but the guy ended up wiping his system trying to remedy it. My Info says:-
Chipset BCM7335
CPU BCM7335BO
Cores 2
Version Helios
Build 004
Kernel 3.1.1
Drivers 2014-03-10
Last Update 2014-04-21
Thank you for any help.
Chipset BCM7335
CPU BCM7335BO
Cores 2
Version Helios
Build 004
Kernel 3.1.1
Drivers 2014-03-10
