VU+ DUO Restart Problem
Lyn Gordon
My 2nd VU Duo has a problem : after having installed BH 2.02 - then setup correct and all my bouquets, this VU duo frequently is starting (unwishesd) new GUI with green information about software correction.
How can this problem be solved - new bootoader also has been installed in advance.
Is this VU defektive ?
Thanks for help
Thanks for help
Upload here a crashlog.
to angelofsky 1980
crashlog - pls help how to upload - ? a crashlog direct from my VU+DUO ?
this problem is quite new for me - thanks
Yes, I can use VuCC 2.0 - installing ***** - I have noticed on the green restart/error-page that error should be sent to /hdd/to crashlog
I am installing a) bootloader 2) BH-images version 2.0.2 - 2.0.3 - 2.04 - restart permanent green error page
1. error line (approx) usr/lib/enigma2/python/components/sources/self.cahnges(self.CHANGES) Poll
FTP with VuCC
will read above thread, further help ??
Thanks so far, hope thread can help, if not I will return
At the moment my 2nd VU+DUO is permanently restarting, accordingly it is not possible to use FTP as long as I cannot get contact with this VU, maybe a self-correction will take place. Have tried to stop the several restarts with pressing menu, without success
Previously I succeeded in installing BH 2.02 Version C ( after 25 restarts) - the VU+Duo was then restarting sometimes in 24 hours
My trials to exclude this problem is now that the box ist restrting all the time, seeing the image 2-3 seconds and then a new restart
Any help possible ?
FTP with VuCC
You asked for holidays. Read Forum Rules, please! No emus here!
OK sorry if I have come in conflict with board rules
have now contact with my VU+DUO with FTP and have found /hdd in this VU with report of my
conflicts in this VU+Duo
which steps has to executed (above thread did not describe this)
will do my best to follow board rules
Have read above link to vucc-vu-control-center
Problem : Which steps in FTP are necessary to solve un-wished / frequent RESTART (green error-page) ?
Any help possible ?
post your crash log - use ftp, go to media/hdd folder when connected to vu (there is a symlink (shortcut) in newest images to your hdd in root directory of your vu) then you will find files look similar to this: 'enigma2_crash_xxxxxxxxxx' where every x is a digit; copy that file and attach to your post here
ot had any
james, reflash your duo and make sure you use compatible plugins with bh image....;)
Hello darian23
thanks for kind answer, unfortunately I have not had any possibility (until now here in Norway) to act on internet. I will return to problem,
hoping to get some assistance from a friend. I will send him Your kind instructions and I defifnitely will report back on this place about
the result.
Sorry about my problems and again many, many thanks for help
Lyn Gordon
ot had any
Hello darian23
the result.
Lyn Gordon
Have found Crash_Log under media/hdd - I will try to enclose the complete Media/hdd content with some
crah-logs
hope my crash_log can be uploaded now - had to change to .txt
also hope for explanation of my problem with restart
thanks in advance
From your log seems there is something wrong with
ValueError: timestamp out of range for platform time_t
but you are using an lod image (2.0.4).
Please update to latest and retry
thanks for help angelofsky 1980 - problem not solved with newest BH
enclosed my latest crash-log
at first a friend put on latest original image using Zero-modem-cable
assume that problem had not bee solved 100% but some advance
then latest BH 2.06 has been installed - USB flash
installed only diseque and started program-search astra
Problem ist still there - Restart - restarted channel without audio -
changing channel audio is working
is there anything possible to solve problem ? How ?
My friend might even be able to solve comainplexer explanations
Thanks ag
hello angelofsky1980 - as already informed today in another item , this receiver had to be repaired byx professonal company, for me the german importer.
different test has been made, finally I was informed, that unfortunately the mainboard had to be replaced. My expeience with the german importer has been very good over years. Cost around 100 euro aceptable, hope not to effect board rules - thnks to angelowsky1980 regards
