VU+ Duo starting problem
shukry
Hello every body
my box stuck on starting i try too many things with no luck
im upgrade the boot loader and install BH using USB and Serial
and all the things are finished normally without errors but after restart its still stuck on starting and no display on the TV.
note : i can access the box from DCC after restarting three or four times.
can anybody help please
Hello every body
Do you have a genuine box?
I have the same problem.The vu dúo is in booting screen for 10 minuts.
Sorry for my english im spanish.
im try it same result
Re do Boot Loader Upgrade again!
Use clean formatted USB,,,and no need to use serial cable...just plug-in the USB @front,, upgrade will take less than 3 second!
Then re install BH image!
(always erase format your USB before any attempt to re using it)
Do you have a USB flash disk connected to the box? If yes, make sure it is NOT ext2 or ext4 formatted. Format it to FAT32 and check again. On VU Duo extx flash disks cause problems with starting.
