I have a Vu Duo box.It is completely genuine and works from 2 years ago.
It worked fine until i upgrade its Bootloader to cfe 3.0. and BH 1.7.2.
After this the box had stucks in " Starting ..." & has been passed by tuening on/off several times. Aftar that i flashed it several times by BH versions+CFE 3.0 but the problem has returned.
So Bad ... Now it has stuck in "Starting ..." Not accept any flash from any usb pen drive model & saize & no from Vu+ Utility.
The putty log says it goes to initilizing Usb then goes to waiting restart after 15 sec.
I measure Voltage of Usb port in start but it is ziro.
All voltages of 3 regulators after power supply are Ok.
All output voltages of power supply are Ok.
I am disapointed from such expensive box it is not acceptable.
So what you think for solving this problem.
1- Is the new Bootloader case of this problem ?
2- Can i downggrade bootlader to earlier version ?
3- Are you know any program apart from Vu+ util can flah box from Serial port ?
4- Any suggestion to bring alive this box ?
Thanks.
Thanks.
