vu duo stop add timer recording
Romman
Hi probably a stupid question but what is the procedure to stop add timer recordings..basically i clicked green to add a timer and set repeat type to repeated/mon-fri but now that this series has ended it is now recording something else that i dont want...just need to know how to stop this..
Many thanks in advance
I take it nobody knows how to stop this problem i have..i,m wondering if i now need to reflash and/or format the hdd which seems a bit extreme.
Btw its bh 1.7.3
Thanks
Into timer menu (Menu > Timer), select the event and press the red button (remove).
Thanks for the above procedure but some programmes are still automatically start recording which I don't want to record and recording stop viewing other channels because there is only one LNB wire comes to box. How do I know which series is in recording mode so I can delete / stop them in one go. All help will be appreciated.
If you installed a plugin to manage recordings, you have to check its settings.
I think what mito is saying is have you installed a plugin such as auto timer which can also control recordings.... These are located in green panel (press green button). If you have not installed such a plugin then all timed recordings should be available to delete or disable as mentioned above menu>timer. Have you installed autotimer or anything else on stb?
