Vu+Duo stucked in deep standby
elec
After I have shut down my VU Duo for transport to my summerhouse it will not start up from deep standby, it is stucked with the red led in the display on. After 10-15 attempts to start with the rear powerswitch the box finally shows starting in the display and then it is ok again util next time I shut down my box.
I use the normal procedure when I shut down my box for transport: Long press off button/shutdown/powerswitch in the rear off, disconnecting cables.....
Image version BH 1.7.3 Kernel version 1.3.1
Is there some problems with 1.3.1 Kernel version?
Is the STB(Duo) working normal now?
Yes. My Duo works fine as long as I don´t do a shutdown and try to do a restart.
Am glad to know that!
Anyway sometimes it takes few mints and up to 1/2 hour ,to cool/clear the STB buffers , thats way it did not turn-on normally!
(I was told that would be the case,,,,;),,,so hopefully its true...:lamo:)
RgdZ
a911
My Duo has the same behaviour for some time, if i turn it off for image change i have to leave it off for about 15 minutes.
Very annoying, it wasn't like this at the beginning.
Will , my duo is the same,,,looking forward for a new Vu Plus releases!
