Dani
I have a Vu+ Duo, it used to work fine on both tuners.
I moved it to a different address that i was installing a new dish at.
In the course of these works, it seems i may have done something to TUNER A.
It seems to have gone deaf... it does not work at good as TUNER B.
Using a known test LNB and cable, i get SNR 96% AGC 89% on TUNER B (get all pics fine)
Using the same LNB and cable for TUNER A, i get a SNR that jumps around from 30 to 80%, to zero, to 16 never stops AGC jumps from 99% to 79% with NO PICS.
Has anyone every encountered this?
I will reflash the unit with the latest firmware, but i fear something much worse has happened.
TUNER A will scan a whole sat, find ALL channels
You can even use Sat Finder and manually add a TP and it will show good strength and quality and a LOCK.
But when you jump back to watch a scanned channel... you get nothing.
