Vu Duo ViX 2.3 (Linux 3.1.1) 25-12-2011
bassethound
New VIX Image Vu+ Duo - Build 153
24/12/2011 - Open ViX 2.3
attachment.php
From VIX Team
Enigma: 24-12-2011.
Enigma Plugins: 24-12-2011.
GCC Version: 4.4.4
Kernel Version: 3.1.1
Drivers: 2011-12-22
This image requires the latest bootloader (attached to this post) to be flashed. This is because Vu+ have changed the way the drivers work. So, before updating your image, you will need to first flash the bootloader, then flash the new image. Flashing of new bootloader only takes a few seconds, so once flashing's completed, then just turn off the box, transfer the new image to the usb stick, and flash with that.
Because of kernel change, you will not be able to perform an online update. A full flash is required for this version of ViX image. But you can use Backup Manager to backup your setting, although any extra plugin will not be reinstalled by the wizard due to the kernel change.
New Features
Subtitle structure - Has been changed and now where subtitles are available you will be able to select subtles either via the subtitles Menu or via the Audio Menu then Yellow button
Where Subtitles are not available you will not be able to bring up the Subtitle Menu or see the Yellow button via the Audio Menu
This is not a bug but rather a change in the Subtitle structure
OpenWebIf - this now how has replaced the old WebIf, and as a result it uses the default port of 8088, if you want you can change it back to 80 in the plugin setup.
Button Mappings
Short Red** & *** - Show current channel EPG info (ViX Single EPG).
Long Red*** - Show current event.
Short Green** & *** - Timers.
Long Green*** - AutoTimer Timers.
Short Yellow*** - EPG Search.
Long Yellow*** - IMDB Database.
Short Blue - Extensions.
Long Blue*** - Plugins Menu.
EPG - Opens ViX EPG.
Left/Right** - Opens ViX QuickEPG.
Up/Down** - Open Full Screen Channel List.
Long Up/Down** - Open Simple TV List.
TV Button** - Open Full Screen Channel List.
Long TV Button - Open Bouquets List.
** Can be changed in ViX Menu
*** Can be turned off in ViX Menu
Special Thanks
  • rytec - for his continued support.
  • zoka.cc for his Picon sets
  • all developers for their plugins used in the feeds of this image.
  • All of the ViX Beta team for their hours of testing and dedication on getting this image working.
  • 'Rob van der Does' & 'belierzz' for their translation work.
  • Silverfox0786 for channel settings and picons.
Requests
If anyone is interested in doing any translation work for the plugins and the image itself, please contact either Andy or Sicilian...
Downloads
