vu duo with vti 4.2 hbbtv help
chrislfc
hello i have installed vti 4.2 and i am trying to use hbbtv and it is saying no detected hbbtv applications. were do i get the applications from and how do i install them
If you can use HBBTV, you will have a popup at lower right on the tv, then with red button you will access to the service.
If you can receive astra 19.2, try for example Das Erste channel.
Mostly German Channels have HBBTV.
See list below:
Astra 19.2:
zdf
3sat hd
zdf hd
zdf info hd
3sat
vox hd
das vierte
daserste
zdf neo
bbc world
cnbc europe
anixe sd
br-alpha
zdf kultur
einfestival hd
swr fernsehen rp
ard
hse24
wdr
