VU+ Duo2 and OpenVPN
Euraptor
Dear All,
In my dream I would like to run OpenVPN on my VU+ box.
I've an PIA account and it works perfectly on linux machines. So I followerd this guide below:
https://www.world-of-satellite.com/showthread.php?52497-Private-Internet-Access-Open-VPN-Setup
and I've managed to install it. Apparently it works as I've a green button in the OpenVPN add-on menu, and the log says that I'm connected.
The problem is that while the OpneVPN is running I got no acces to internet, I've checked with the plugin IP Checker and I only get the private IP but not the pubblic. Obviously all the streams and connections stops.
When I stop the VPN they come back and the IP checker give me the right IP's.
Thant's the log:
Fri Aug 2 11:43:48 2019 WARNING: file '/etc/openvpn/password.txt' is group or others accessible
Fri Aug 2 11:43:48 2019 OpenVPN 2.4.3 mipsel-oe-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jul 2 2019
Fri Aug 2 11:43:48 2019 library versions: OpenSSL 1.0.2m 2 Nov 2017, LZO 2.10
Fri Aug 2 11:43:48 2019 TCP/UDP: Preserving recently used remote address: [AF_INET]46.167.185.227:1198
Fri Aug 2 11:43:48 2019 UDP link local: (not bound)
Fri Aug 2 11:43:48 2019 UDP link remote: [AF_INET]46.167.185.227:1198
Fri Aug 2 11:43:49 2019 [b120d7accb4248d556624834db0ec143] Peer Connection Initiated with [AF_INET]46.167.185.227:1198
Fri Aug 2 11:43:50 2019 auth-token received, disabling auth-nocache for the authentication token
Fri Aug 2 11:43:50 2019 TUN/TAP device tun0 opened
Fri Aug 2 11:43:50 2019 do_ifconfig, tt->did_ifconfig_ipv6_setup=0
Fri Aug 2 11:43:50 2019 /sbin/ip link set dev tun0 up mtu 1500
Fri Aug 2 11:43:50 2019 /sbin/ip addr add dev tun0 local 10.15.12.6 peer 10.15.12.5
Fri Aug 2 11:43:50 2019 Initialization Sequence Completed
Can anyone enlight me?
I don't really thing is about the loggin but something else which is not clear to me.
Many thanks in advance.
Euraptor
