Hello everybody, a friend of mine have a big problem: vu duo2 can´t boot stop on splash image, he tryed few images & same pb... any help?
log with putty
Thanks
log with putty
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.06.18 14:01:55 =~=~=~=~=~=~=~=~=~=~=~=
BCM74250012
M0
M1
01CZL2=1
LLMB=0000C000
BP=02000000
L2Cfg=1E7AD627
L2Buf=77707711
BrCfg=F01C200E
BrMod=02800801
BrZp0=44000000
BrZp1=00002000
CFE ver 2.333.20130710, Endian Mode: Little
Build Date: Mon Jul 15 19:29:18 2013 Vuplus Team
Copyright (C) Broadcom Corporation.
CPU speed: 1305MHz
DDR Frequency: 800 MHz
DDR Mode: DDR3
Total memory(MEMC 0): 1024MB
MEMC 0 DDR Width: 32
Total memory(MEMC 1): 1024MB
MEMC 1 DDR Width: 32
Boot Device: NAND
Total flash: 512MB
RTS VERSION: 20120919184252_7425_single_encode
ETH0_PHY: RGMII
ETH0_MDIO_MODE: 1
ETH0_SPEED: 1000
ETH0_PHYADDR: probe
SCB CLOCK = 277MHz
Initializing USB.
USB: Locating Class 09 Vendor 0000 Product 0000: USB Root Hub
CFE initialized.
USB: New device connected to bus 3 hub 1 port 1[J
USB: Resetting device on bus 3 hub 1 port 1[J
USB: Locating Class FF Vendor 148F Product 5372: Driver not found.
USB: New device connected to bus 2 hub 1 port 1[J
USB: Resetting device on bus 2 hub 1 port 1[J
USB: Locating Class 08 Vendor 058F Product 6387: Mass-Storage Device
USBMASS: Unit 0 connected[J
waiting for usb...done
checking usb
No Priority Usb
checking front key
Checking usbdisk0:/vuplus/duo2/ignore.update......NO
Checking usbdisk0:/vuplus/duo2/force.update......NO
Checking usbdisk0:/vuplus/duo2/cfe_cfe_auto.bin......NO
Checking usbdisk0:/vuplus/duo2/root_cfe_auto.bin......YES
Checking usbdisk0:/vuplus/duo2/splash_cfe_auto.bin......YES
Checking usbdisk0:/vuplus/duo2/kernel_cfe_auto.bin......YES
Checking usbdisk0:/vuplus/duo2/reboot.update......YES
waiting for update key
readFrontKey 0x0
FrontPanel Key : d1, 1
Update
Reading usbdisk0:/vuplus/duo2/cfe_cfe_auto.bin: >> Skipping...: File not found
Reading usbdisk0:/vuplus/duo2/initrd_cfe_auto.bin: >> Done. 6310063 bytes read
Programming...
done. 6310063 bytes written
Reading usbdisk0:/vuplus/duo2/splash_cfe_auto.bin: >> Done. 1036856 bytes read
Programming...
done. 1036856 bytes written
Reading usbdisk0:/vuplus/duo2/kernel_cfe_auto.bin: >> Done. 4398409 bytes read
Programming...
done. 4398409 bytes written
Loader:elf Filesys:raw Dev:flash0.initrd File: Options:bmem=192M@64M bmem=512M@512M
Loading: 0x80001000/13682176 0x80d0d600/122192 Entry address is 0x8054e7c0
Starting program at 0x8054e7c0
Linux version 3.3.6-1.2-gef4d924-dirty (shcheong@NcshN2) (gcc version 4.5.3 (Broadcom stbgcc-4.5.3-2.2) ) #13 SMP Wed Feb 20 17:50:51 KST 2013
Fetching vars from bootloader... found 14 vars.
Options: moca=0 sata=0 pcie=0 usb=1
Using 1024 MB + 1024 MB RAM (from CFE)
bootconsole [early0] enabled
CPU revision is: 00025a11 (Broadcom BMIPS5000)
FPU revision is: 00130001
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
memory: 30000000 @ 20000000 (usable)
bmem: adding 192 MB RESERVED region at 64 MB (0x0c000000@0x04000000)
bmem: adding 512 MB RESERVED region at 512 MB (0x20000000@0x20000000)
Initrd not found or empty - disabling initrd
Zone PFN ranges:
Normal 0x00000000 -> 0x00050000
Movable zone start PFN for each node
Early memory PFN ranges
0: 0x00000000 -> 0x00010000
0: 0x00020000 -> 0x00050000
PERCPU: Embedded 7 pages/cpu @81a09000 s5632 r8192 d14848 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259584
Kernel command line: bmem=192M@64M bmem=512M@512M
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Primary instruction cache 32kB, physically tagged, 4-way, linesize 64 bytes.
Primary data cache 32kB, 4-way, linesize 32 bytes.
MIPS secondary cache 256kB, 8-way, linesize 128 bytes.
Memory: 303064k/1048576k available (5515k kernel code, 745512k reserved, 1110k data, 6736k init, 0k highmem)
Hierarchical RCU implementation.
NR_IRQS:160
Detected MIPS clock frequency: 1305 MHz (163.131 MHz counter)
Calibrating delay loop... 869.37 BogoMIPS (lpj=434688)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
SMP: Booting CPU1...
SMP: CPU1 is running
Brought up 2 CPUs
devtmpfs: initialized
bmem: adding extra 1024 MB RESERVED region at 2304 MB (0x40000000@0x90000000)
NET: Registered protocol family 16
USB0: power enable is active high; overcurrent is active low
USB1: power enable is active high; overcurrent is active low
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.24.
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource wktmr
NET: Registered protocol family 2
IP route cache hash table entries: 8192 (order: 3, 32768 bytes)
TCP established hash table entries: 32768 (order: 6, 262144 bytes)
TCP bind hash table entries: 32768 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 32768 bind 32768)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
NTFS driver 2.1.30 [Flags: R/W].
msgmni has been set to 591
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10406b00 (irq = 62) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x10406b40 (irq = 63) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10406b80 (irq = 64) is a 16550A
brd: module loaded
loop: module loaded
brcmstb_nand: NAND controller driver is loaded
Found PHY at Address 3
Config GPHY through MDIO
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 66, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 67, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ehci-brcm ehci-brcm.2: Broadcom STB EHCI
ehci-brcm ehci-brcm.2: new USB bus registered, assigned bus number 3
ehci-brcm ehci-brcm.2: irq 71, io mem 0x10490300
ehci-brcm ehci-brcm.2: USB 0.0 started, EHCI 1.00
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
ehci-brcm ehci-brcm.3: Broadcom STB EHCI
ehci-brcm ehci-brcm.3: new USB bus registered, assigned bus number 4
ehci-brcm ehci-brcm.3: irq 72, io mem 0x10490500
ehci-brcm ehci-brcm.3: USB 0.0 started, EHCI 1.00
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 5
ohci-brcm ohci-brcm.0: irq 68, io mem 0x10480400
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 1 port detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 6
ohci-brcm ohci-brcm.1: irq 69, io mem 0x10480600
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 1 port detected
ohci-brcm ohci-brcm.2: Broadcom STB OHCI
ohci-brcm ohci-brcm.2: new USB bus registered, assigned bus number 7
ohci-brcm ohci-brcm.2: irq 73, io mem 0x10490400
hub 7-0:1.0: USB hub found
hub 7-0:1.0: 1 port detected
ohci-brcm ohci-brcm.3: Broadcom STB OHCI
ohci-brcm ohci-brcm.3: new USB bus registered, assigned bus number 8
ohci-brcm ohci-brcm.3: irq 74, io mem 0x10490600
usb 4-1: new high-speed USB device number 2 using ehci-brcm
hub 8-0:1.0: USB hub found
hub 8-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ALSA device list:
No soundcards found.
TCP cubic registered
lib80211: common routines for IEEE802.11 drivers
PM: CP0 COUNT/COMPARE frequency does not depend on divisor
EBI CS0: setting up NAND flash (primary)
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit)
brcmnand brcmnand.0: 1024MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, Hamming ECC
Bad block table found at page 524224, version 0x01
Bad block table found at page 524160, version 0x01
Creating 3 MTD partitions on "brcmnand.0":
0x000002700000-0x000040000000 : "rootfs"
0x000000000000-0x000040000000 : "entire_device"
0x000000200000-0x000000900000 : "kernel"
Freeing unused kernel memory: 6736k freed
starting pid 40, tty '': '/etc/init.d/rcS'
Mounting virtual filesystems
mount: mounting debugfs on /proc/sys/debug failed: No such device
Starting mdev
* WARNING: THIS STB CONTAINS GPLv3 SOFTWARE
* GPLv3 programs must be removed in order to enable security.
* See: http://www.gnu.org/licenses/gpl-faq.html#Tivoization
Configuring eth0 interface
Configuring lo interface
Starting network services
starting pid 67, tty '': '/etc/init.d/rcS2'
Vuplus Update Start..
checking sda ..
usb 3-1: new high-speed USB device number 2 using ehci-brcm
scsi0 : usb-storage 3-1:1.0
checking sda ..
scsi 0:0:0:0: Direct-Access Generic Flash Disk 8.07 PQ: 0 ANSI: 4
sd 0:0:0:0: [sda] 15974400 512-byte logical blocks: (8.17 GB/7.61 GiB)
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1
sd 0:0:0:0: [sda] Attached SCSI removable disk
checking sda ..
count, 4
sda1 is to be mounted ..
update_rootfs /mnt/sda1
The system is going down NOW!
Sent SIGTERM to all processes
Sent SIGKILL to all processes
Requesting system reboot
Restarting system.
BCM74250012
M0
M1
01CZL2=1
LLMB=0000C000
BP=02000000
L2Cfg=1E7AD627
L2Buf=77707711
BrCfg=F01C200E
BrMod=02800801
BrZp0=44000000
BrZp1=00002000
CPU speed: 1305MHz
DDR Mode: DDR3
Boot Device: NAND
Total flash: 512MB
ETH0_PHY: RGMII
ETH0_MDIO_MODE: 1
ETH0_SPEED: 1000
ETH0_PHYADDR: probe
SCB CLOCK = 277MHz
Initializing USB.
CFE initialized.
checking usb
No Priority Usb
checking front key
BCM74250012
M0
M1
01CZL2=1
LLMB=0000C000
BP=02000000
L2Cfg=1E7AD627
L2Buf=77707711
BrCfg=F01C200E
BrMod=02800801
BrZp0=44000000
BrZp1=00002000
CPU speed: 1305MHz
DDR Mode: DDR3
Boot Device: NAND
Total flash: 512MB
ETH0_PHY: RGMII
ETH0_MDIO_MODE: 1
ETH0_SPEED: 1000
ETH0_PHYADDR: probe
SCB CLOCK = 277MHz
Initializing USB.
CFE initialized.
checking usb
No Priority Usb
checking front key
Checking usbdisk0:/vuplus/duo2/root_cfe_auto.bin......NO
Checking usbdisk0:/vuplus/duo2/splash_cfe_auto.bin......NO
Checking usbdisk0:/vuplus/duo2/kernel_cfe_auto.bin......NO
Starting splash screen.
Found splash image - Width = 720 Height = 480
Non Interlaced Replace list 043f8100 0c800000Interlaced Replace list 043f86a0 0c8005a0
Loader:elf Filesys:raw Dev:flash0.kernel File: Options:ubiroot rootflags=sync bmem=192M@64M bmem=458M@512M memc1=590M
Loading: 0x80001000/8535040 0x80824c00/197520 Entry address is 0x80660be0
Starting program at 0x80660be0
Linux version 3.13.5 (oe-user@oe-host) (gcc version 6.3.0 (GCC) ) #1 SMP Fri Nov 23 15:48:28 UTC 2018
Fetching vars from bootloader... found 17 vars.
Options: moca=0 sata=1 pcie=0 usb=1
CPU0 revision is: 00025a11 (Broadcom BMIPS5000)
memory: 31400000 @ 90000000 (usable)
bmem: adding 384 MB RESERVED region at 512 MB (0x18000000@0x20000000)
Zone ranges:
Normal [mem 0x00000000-0x4fffffff]
HighMem [mem 0x50000000-0xc13fffff]
Movable zone start for each node
Early memory node ranges
node 0: [mem 0x00000000-0x0fffffff]
node 0: [mem 0x20000000-0x4fffffff]
node 0: [mem 0x90000000-0xc13fffff]
PERCPU: Embedded 7 pages/cpu @82012000 s7168 r8192 d13312 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 461824
Kernel command line: libata.force=1:1.5Gbps bmem=192M@64M bmem=384M@512M memc1=788M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync
Memory: 1239824K/1855488K available (6570K kernel code, 358K rwdata, 1192K rodata, 248K init, 147K bss, 615664K reserved, 806912K highmem)
NR_IRQS:160
Measuring MIPS counter frequency...
Detected MIPS clock frequency: 1305 MHz (163.130 MHz counter)
Console: colour dummy device 80x25
Calibrating delay loop... 864.25 BogoMIPS (lpj=432128)
CPU1 revision is: 00025a11 (Broadcom BMIPS5000)
Brought up 2 CPUs
bmem: adding extra 236 MB RESERVED region at 3092 MB (0x0ec00000@0xc1400000)
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.17
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
Switched to clocksource wktmr
FS-Cache: Loaded
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
bounce pool size: 64 pages
FS-Cache: Netfs 'nfs' registered for caching
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
FS-Cache: Netfs 'cifs' registered for caching
Key type cifs.spnego registered
Key type cifs.idmap registered
fuse init (API version 7.22)
msgmni has been set to 845
serial8250.0: ttyS0 at MMIO 0x10406b00 (irq = 62, base_baud = 5062500) is a 16550A
bootconsole [early0] disabled
serial8250.0: ttyS1 at MMIO 0x10406b40 (irq = 63, base_baud = 5062500) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10406b80 (irq = 64, base_baud = 5062500) is a 16550A
loop: module loaded
ahci strict-ahci.0: can't get clock
ahci strict-ahci.0: SSS flag set, parallel bus scan disabled
ahci strict-ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
ahci strict-ahci.0: flags: ncq sntf stag clo slum part
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: FORCE: PHY spd limit set to 1.5Gbps
ata1: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x100 irq 42
ata2: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x180 irq 42
bcmgenet: configuring instance #0 for external RGMII
ata1: SATA link down (SStatus 0 SControl 310)
ata2: SATA link down (SStatus 0 SControl 300)
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR SANYO protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
usbcore: registered new interface driver btusb
hidraw: raw HID events driver (C) Jiri Kosina
TCP: cubic registered
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
Key type dns_resolver registered
NAND device: 1024MiB, SLC, page size: 2048, OOB size: 64
Creating 4 MTD partitions on "brcmnand.0":
0x000002700000-0x000040000000 : "rootfs(redundant)"
0x000000900000-0x000000b00000 : "mac"
UBI: attaching mtd0 to ubi0
random: nonblocking pool is initialized
UBI: scanning is finished
UBI error: vtbl_check: bad CRC at record 21: 0xe2cd3ead, not 0xf116c36b
Volume table record 21 dump:
reserved_pebs 0
alignment 0
data_pad 0
vol_type 0
upd_marker 0
name_len 0
name NULL
UBI warning: process_lvol: volume table copy #1 is corrupted
UBI: volume table was restored
gluebi (pid 1): gluebi_resized: got update notification for unknown UBI device 0 volume 0
UBI: volume 0 ("rootfs") re-sized from 977 to 7716 LEBs
UBI: attached mtd0 (name "rootfs", size 985 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 7876, bad PEBs: 4, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 68/44, WL threshold: 4096, image sequence number: 2056857951
UBI: available PEBs: 0, total reserved PEBs: 7876, PEBs reserved for bad PEB handling: 156
UBI: background thread "ubi_bgt0d" started, PID 53
ALSA device list:
UBIFS: parse sync
UBIFS: background thread "ubifs_bgt0_0" started, PID 56
UBIFS error (pid 1): ubifs_scan: corrupt empty space at LEB 3:3663
UBIFS error (pid 1): ubifs_scanned_corruption: corruption at LEB 3:3663
UBIFS error (pid 1): ubifs_scanned_corruption: first 8192 bytes from LEB 3:3663
UBIFS error (pid 1): ubifs_scan: LEB 3 scanning failed
UBIFS: background thread "ubifs_bgt0_0" stops
VFS: Cannot open root device "ubi0:rootfs" or unknown-block(8,1): error -135
Please append a correct "root=" boot option; here are the available partitions:
1f00 1008640 mtdblock0 (driver?)
1f01 1008640 mtdblock1 (driver?)
1f02 7168 mtdblock2 (driver?)
1f03 2048 mtdblock3 (driver?)
1f04 956784 mtdblock4 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(8,1)
Rebooting in 180 seconds..�
Thanks
