Vu Duo2 CFE V2
dpo111
przy uruchamianiu dekodera na wyswietlaczu pojawia sie komunikat "Vu Duo2 CFE V2". Chcialem wgrac przez usb najnowszy software ale dekoder nie czyta usb. Dlaczego nie moge zaaktualizowac dekodera?? Prosze o pomoc
have you formatted your usb stick to fat32 ?
if you have have you tried anouther usb stick ?
have you taken the vuplus from the zip folder and sent the vuplus folder
to your usb stick without opening the folders any further?
i have a couple of usb sticks my duo2 will not recognise this is why i said
try a different usb stick to be sure it's not the usb stick giving the problem
