antoine3_dupres
I recently bought a vu duo2 and installed the latest bh on it. After one week i have started tolook at the temperature in the box (with the lcd color screen) and i noticed that by default there was with Bh a plugin installed "manual fan control".
As i noticed that the fan was stopped while in stand by i decided to keep it on always (otherwise temperature was around 37 with a room temp at 24).
However i do not find rational in this plugin as the fan speed is always set at the same rpm in standby and during use.
so i installed another plugin "fan control2", that is supposed to regulate the temperature by acting on the fan depending on the temperature.
However i read on the net:
- fan control 2 was designed for solo2 and shall not be used on duo2!
- you do not need any plugin for temp control on duo2. But then why is BH installed with a plugin?
On top of this i was wondering how i could have 2 plugins installed trying to both drive the fan! I cannot remove the manual fan control as the opkg uninstall command is telling that there is a dependency on another module....so i did not want to force the desinstall and start to mess up my config.
So my question: what fan control plugin to use on duo2(if any)
Views will be appreciated.
Thanks
Thanks
